Nomadac
Jul 02, 2015Explorer
Busskipper wrote:captron33 wrote:
I have had this 40 ft. Coach since new. Today is first time auto leveler did not work. When i push autolevel it just makes a noise and shuts off. It doesn,t deflate the airbags or start any movement of the jacks. Anyone have any help for me??? Thanks
Had the same issue on mine after it had been sitting for a while - Ground wire and the connectors all needed to be cleaned up. If I recll - ended up having the local mobile tec come out to find it 9on my Coach it was passenger side front under the bumper/fender) - took some time but everything worked as new after the connections and the ground were cleaned.
Hope this helps,
If this doesn't correct the problem I would contact Equalizer for their technical support, Friday as they will be closed for the 4th and not sure if open on Monday.
38,769 PostsLatest Activity: Apr 03, 2026
