Krusty
Nov 01, 2017Nomad II
Did the cruise control indicator work before the cruise quit working? If so, this could be a clue. The most common problem with this system is the deactivation switch on the master cylinder. Easy test is to disconnect the switch and jump the two terminals in the harness connector together and take it for a drive. If it works now, replace the switch. Also check the switch for brake fluid leakage into the connector. There was a recall on this switch, it could be covered.
38,766 PostsLatest Activity: Jan 10, 2026
