FIRE_UP
Nov 04, 2019Explorer
visavis47 wrote:
I currently have a leak in the passenger side rear wheel inner seal. All I can find is workhorse part number (way too expensive). Does anyone have the manufactures part number?? Would like to have both outside and inside seal part numbers...Thanks
Unless things have changed dramatically, there will be NO outside axle seal. All that seals the diff fluid from escaping is the end of the hub, is the axle end, with all the bolts tight. About 98% of the diff builders for the larger truck axles, use no actual gasket. They may use Silicone.
As for the inner one, why don't you just simply remove the hub and wipe things off and see for yourself, what the number is? It will be right there, on the outside of the seal. It could be a "CR" or, Chicago Rawhide brand. But, this way you'll know EXACTLY what the seal part number is and you can cross reference it to your hearts content.
Scott
38,777 PostsLatest Activity: May 20, 2026
