- imgoin4itExplorerIf it is Atwood level legs you probably have to have the engine running to have enough voltage to operate them. They might power up with engine not running but need engine running to work.
- accsysExplorerThough there could be one, I haven't heard of another on/off except for the one on the keypad in your left console. I don't know what your experience level is or what you have tried but the ignition switch must be turned on as well. The actual control module is located on the roof of the first bay behind the PS front wheel.
- Atwood on Tiffin. The Main Atwood controller is located in one of 2 places. Either the LF storage in front of the LF tire. Or in the Right side storage behind the RF tire. In either of the first 2 compartments and will be mounted to the Ceiling of the storage compartment. There is no other switch other than the Ignition switch. Doug
- donfrumpExplorer
TROPYEK wrote:
Atwood leveler, It shows on diagram of pad there is a on off switch located somewhere besides the one on leveler pad, we have no power to keypad, checked all fuses good cant locate switch would anybody know location, an hopefully this will solve our problem
thanks John
you do have the key in the on position? there will be a fuse on the controller if so equipped and a fuse in the house 12V fuse department
most likley
38,758 PostsLatest Activity: Nov 06, 2025
