TROPYEK's avatar
TROPYEK
2008 allegro bus changed out king dome for weigand t4
have 2008 allegro bus removed kingdome unable to get weigand T4 antenna operating, there is a tuner box on drawing for kingdom that everything is connected to that cable is connected does anyone know where this is located.
Thanks John
  • Doug Thank you so much, I had thought it was a simple installation looking at drawing from weingard it would have been if I knew were tuners were. headed over there in a little while. I'll let you know.
    Thanks, John
  • I guess you are trying to use the Coax cable from the KingDome for the WINEGARD T4 SAT ANTENNA. The KingDomes coax goes to a tuner box and ALL the tunerboxes and controls must be removed for your T4 to work. On Tiffin they installed the King Dome Tuners in 4 places depending on year and model
    1. BEHIND the center overhead LCD TV above the dash. You must remove the TV for access to the Tuners and coax cables
    2. BEHIND the overhead access cabinet in front of the drivers side Dash
    3. BEHIND the Same type access Cabinet in front of the Pass seat
    4. Beside the drivers chair the overhead cabinet had access panels where the Inverter and slide switches. Some models had them there. Doug
