Dale_Traveling
May 20, 2016Explorer II
The 30Q is probably the most basic class A you can find. Not having slides can be a down check for some potential buyers while others seek them out. In general being a basic and simple coach keeps the reliability and functionality high. Items such as the fridge, HAVC, potable water systems, and such are no different then what you will find on more expensive rigs.
My coach is two years older and one model up but pretty close in chassis, general construction and amenities. Probably the biggest problem to check for is delamination anywhere in the side walls and roof leaks at the seams. Check carefully around the below floor storage doors for soft spots. Roof sealants should be soft with no cracks or splits. The production line does a bare bones job of sealing the coach during construction and there are a lot of places for potential water to get in.
Maintenance records will be a bonus and learn how to read tire date codes. Suspect the tires will be original and should be considered for replacement. No real problems with the chassis just leave the spark plugs alone. There are a few chassis maintenance items that are based on time OR mileage what should have been accomplished even if the coach was only driven 2000 miles.
