eHoefler
Oct 01, 2023Explorer II
A long block is not the same as a complete engine, it is the block, crank, rods, pistons, and cam. That is it. You still have to reman the heads, turbo, pump, injectors, valve train, gaskets, etc.. Then you have to flush cooling system and after cooler. Not to mention all the other parts that need replaced, coolant hoses, charged air boots, fuel lines, filters, oil, coolant, etc.. The access is nothing but a pain in the ass and removal of the engine/transmission assembly is the only option to even try to work on it. It has to be dropped from the bottom or slid out the back. That takes a lot of man power and equipment. Sound's steep, but that is what you get in a pusher motor home
