rvrepairnut
Mar 23, 2012Explorer
jetartessales wrote:
rvrepairnut:
The surging I refer to is that of the water pump which you can hear and feel through the shower floor, constantly in cadence, on-off, on-off, on-off. . . .as long as the water is on. I am told this is normal however, this was not the way the water system performed in our 08 Fleetwood Discovery. With each surge (on-off) you get alternating scalding hot, then chilling cold water from the shower head. It is all but impossible to adjust the two control knobs.
Any ideas ?
As for the leveling. . .are you ready for this. . .? The PowerGear system as installed will not let you switch from "auto" to manual. It is one or the other. You select "ON" and then must choose either "auto" or "manual." Once selected, the air exits the airbag ride system then commences to level the coach. If you start with "auto" you must remain with "auto." If I want to manually level the coach or make minor adjustments to the coach level, I must select "raise" all jacks and wait an estimated 3-4 minutes until jacks are completely up, stored and the jacks down alarm stops. Then, and only then, you can select "manual" for leveling. Can't have it both ways! My Fleetwood Discovery was just the opposite. . .use "Auto" then fine tune with "manual." Really frustrating is the well known fact, PowerGear will not entertain any calls from the consumer for assistance. . .
Perhaps this is an installation / set up issue from time of manufacture by Winnebago.
Thanks for your input. . .
Eric and Anita Clapp
Well I still say the water pump should pump constant pressure and not surge so there is something wrong there
As far as jacks go i see your point as mine work either way any time you want(like your old ones)
Maybe phone Dan at Valid manufacturing in Salmon Arm BC Canada as hes the guy that made the jack system and he may shed some lite on your problem.I have talked to him about my neighbours PowerGear air level system and hes a nice guy and willing to help if he can .
Dan North
> > Service Coordinator
> > Valid Manufacturing Ltd.<>>
> > [email protected]
> > Phone: (250) 832-6477 x 218
> > 24H Service: (250) 804-1247
> > Fax: (250) 832-7746
38,782 PostsLatest Activity: Sep 10, 2026
