workhardplayha1
Mar 23, 2012Explorer
HeresLucy wrote:
I seem to recall the lemon law s applicable to the chassis only. Is the box mounted on the chassis crooked? Is it a Freightliner - if so, take it to Gaffney and have them check for accuracy. I think there are guidelines on how close it must be. If it's way off, then you probably will get more attention from the powers that be @ Winnebago. Freightliner and the tire manufacturer would have issues if it is mounted incorrectly -- wear and tear chassis, tire safety etc. Could a misaligned housing be causing issues with the slides not working properly?
A Tiffin owner had this problem years ago and Tiffin ended up buying it back. You ought to post some pictures so others can see anything you might be missing.
Be sure to document everything. Keep a written audit trail of your appts - communications. Who does what, when.
FL Lemon Law
Florida Lemon Law only covers the "driving portion" of the coach. The "house" components are not covered.
38,782 PostsLatest Activity: Sep 10, 2026
