RayChez
Jul 08, 2012Explorer
Most of these things can be adjusted with minimal mechanical knowledge. If you crawl under the coach and look at your levelers you will see that there is a switch that will tell you when the leveler is up. Since the coach is new it might be that the switch is not adjusted properly.
I agree that these adjustments should all be taken care off before they leave the plant, but they are not always. These modern houses on wheels just have too many things that can go wrong or need adjustments.
There are many RVers that have no knowledge on how thing work. You have to be a lucky person to get the perfect coach. I guess I can say I am one of those lucky persons with minimal problems. Most of the problems I have been able to take care off.
All I can say is welcome to RVing and hope that your problems eventually will be taken care off.
38,782 PostsLatest Activity: Sep 10, 2026
