BUTCHPHI
Jul 11, 2012Explorer
I've read this post from start to finish and was not going to comment, but after reading this and many others like it I can't resist. Going back to the original post (the very first list) two things jump out. First is that the jacks don't work properly. From what I read they must not have ever worked properly from day one and I would make the same comment about the slides. At the very least those two systems must have / should have been run through their paces at least a few times before the sale. If that is true why on earth did you ever take delivery of this piece of junk? As I read this thread and ones like it I have the same observations. I am not saying you ( and others in a similar situation) don't have a lemon but what responsibility do you (and others like you in a similar situation) have for buying it. Now if you bought a new rig and everything was in fine shape (after being thouroughly tested by you) and then things start going bad after delivery (although I have never seen that situation, but I'm sure it has happened on occasion) then I have sympathy. This post is probably not welcome but I believe people need to take some responsibilty for their bad decisions and just get on with getting it corrected or get rid of it and take it as a lesson learned. I also believe that there are some people who should not own a complex piece of equipment such as a motorhome.
38,782 PostsLatest Activity: Sep 10, 2026
