- 1492ModeratorMoved from Forum Technical Support
- lanerdExplorer IIOk, sorry....didn't realize it was a mh. There are steering stabilizers available that might help you out. Tire pressure is very important...having too much air in the front tires can sometimes cause problems as well as having a large overhang behind the rear tires.
Do a search here on rv.net on this subject. You'll find a whole bunch of info.
good luck
Ron - 2oldmanExplorer IIAdvice too.
- schb8182ExplorerNo; this is a motorhome not a travel trailer. I am looking to upgrade the suspension. I would like advise on what can be done to make it drive better on longer trips, and thanks for noticing the spelling error. (just saying)
- lanerdExplorer III seriously doubt if it is a problem with your trailer's suspension. More than likely, your tongue weight is too low. Typically, you need about 12 to 13 percent of the trailer's total weight on the tongue.
Also, do you have an integrated weight distribution/sway control device? Is it adjusted correctly?
Tires on the trailer and the tow vehicle can cause sway problem also.
You need to fill us in with more info.
Ron
PS...it's a Coachmen...not Coachman. Just saying ;)
38,763 PostsLatest Activity: Dec 05, 2025
