CT51
Feb 21, 2014Explorer
My 319DSF is dry as well. In my case, locating where the water was entering was not hard. I have taken several other pre-emptive measures to make sure water can not enter. The most recent was to drill two 1/8" holes in the trim where it goes under the overhead cab. This is the trim you would see if you were sitting in the RV and looked thru the windshield and up at the bottom of the overhead cab. In talks with Coachmen, and from experience gathered from reading all the posts, most instances of leaks in Leprechauns come from water entering this trim on the top sides of the cabover, where the awning trim meets this trim. If water gets in, it follows the trim forward, then down the side, and then fills up along the bottom as it has nowhere to go. So, I first verified that I had the trim piece totally sealed, and after several rain and hose checks that it was dry, then drilled the holes so that if water ever does get in some day, it will just drain back out before it can back up into the overhead. So, if it's ever raining like crazy one day while I'm camping, I'll just glance at those holes occasionally, and if water is coming out, I'll know I need to check sealing again. What won't happen though is for water to back up into the overhead. These holes are simply weep holes at the lowest spot, just like window frames. Not all class C's have trim like Leprechauns. While the trim used creates an opportunity for water entry at the top sides, it also creates an opportunity to add the weep holes and let the water back out. Happy to say RV has been 100 percent trouble free in every other way. Just returned from trip to south Georgia to get some warm weather and RV was great. Still ran the fireplace at night for ambiance, just without the heat!
CT51
CT51
