gjhendr's avatar
gjhendr
2014 Thor ACE 29.2 review
Picked up the new 2014 in February and this past weekend was the first outing. The Ford V10 is more than adequate for the motorhome as long as you can keep it between the lines. Steering is vague and it wonders all over the road. Not fun to drive! A number of problems also showed up. The right side marking light failed. The drain hose from the black water tank to the waste pump has holes in it due to a hose clamp rubbing on it. The hose clamp from the black water tank was not installed over the connection thus leaked. The "out side shower" is in a compartment under the slide out making it useless. (Thor stated that they put it there because campers did not want mud by their camper) The bottom of the shower was loose and not sealed. Looking under the camper, the steel framing that Thor installed over the Ford frame was not painted/undercoated and was very rusty. The upper driver side clamp that holds the motor cover could not be latched as the bottom of the dashboard interferes. The instrument panel is very hard to read (a Ford problem). No easy way to get up and in the front bunk with no net to prevent the kids from falling out. The cabinet location for the DVD player has, from front to rear, HDMI cable, 110 outlet and in the back, the antenna switch/amp, thus you can not see the little red light and you need to reach over the outlet to get to the amp. Last time I checked, the HDMI connection on a DVD played is in the back! No 12 volt outlet anywhere. Found about 5ft piece of wire stuffed behind the fresh water tank. The RV heater is under the bed and makes considerable noise. The fuse/converter box is also under the bed and it has a fan that makes some noise. A lot of wind/rattle noise going down the road with the little door on the right side of the steps being a problem. The fresh water pump is week and may need to be replaced, but CW can not get to it and the other issues till June.
  • Sorry to hear, was your shake-down camping, by chance was it at Carowinds?
    Markiemark:C
  • Really sorry to here of your problems but THOR is not noted as a first rate company. Really low end products.
    JMHO
  • And that's why I love my Jayco. Called them Friday, took it in for some warranty work this morning. Said 7-10 days it will be ready to pick up. Richardson's RV and Jayco 5th Wheel - the only way we do business.
  • Kapow! Holy******Batman. That is exactly the unit we have been working with a salesman to buy at Motorhome Specialties in Alvarado TX. Thanks for the heads up and keep spreading the word. No way I'm gonna buy that POS now. Good luck going down the warranty repair road.
  • Anonymous's avatar
    Anonymous
    Not applicable
    Sorry to hear about your problems. You'll find many negative comments about Thor products in this forum.
  • Wow! Sorry to hear your report and that it has been such a bad experience. Hope CW gets it back in one piece. Guess that takes the Thor off the table for us! Thank you.
