Rwake901's avatar
Rwake901
2015 Allegro 31SA - No Engine Power
Picked up our new 2015 Allegro 31 SA Feb. 20 drove it home 100 miles no problems. Parked it in our driveway took it for a drive Saturday March 14 for the first time since we brought it home. The engine has no power. It starts fine, idles perfect but when you step on the gas to go the engine revs just a little then falls back down to and idle. If you pump the accelerator you can get it to go but it takes a while. Once you finally do get it up to speed say 65 mph it runs fine. When you stop to take off again the only way you can get it going is easy on the accelerator until it dies out then start pumping. This is the Ford F53 chassis with the V-10 with 900 miles on it. The first thing I thought of was water in the fuel, I've put 8 bottles of Heet in it hasn't helped yet. Of course I can take it to Ford but I wanted to make sure it wasn't something simple first. Anybody have any ideas?
  • Take it to dealer do not attempt to fix it yourself. By taking it to dealer you have established a history of a problem. Which will help if you have a problem later on.
  • Do not pass go.
    Do not collect $200.
    Straight to dealer.
    Don't mess with it.
  • Sounds like a fuel filter problem. This coach could have sat for a year before you got it so it is possible that the gas went bad or some debris settled in the tank.
  • Call the dealer.
    Contact Tiffin as well.
    Bob Tiffin 256-356-8661 ext. 2206
    Van Tiffin 256-356-8661 ext. 2224
    Lex Tiffin 256-356-8661 ext. 2231
    Tim Tiffin 256-356-8661 ext. 2223
    Main Office / Manufacturing 256-356-8661
    Service & Technical Assistance 256-356-0261 Press 6
    Ford 1 (800) 444-3311
  • I think it's deeper than just WIF. Time to let the dealer fix it.
    At least it's under warranty!
