HD8100A
Dec 21, 2014Explorer
Haven't fully looked at the specifications of the 2015 but we have the 2010 4WD and it can be flat towed with no changes required. The 4WD comes standard with a electronic drive shaft disconnect. In 2010 only the 4WD was flat towable I assume this would be the same case for 2015. Takes about 20 seconds to disconnect the drive shaft just hold down the 2W and 4W high buttons for 10 seconds. In 2010 there is no steering wheel lock, so no fuse to remove. Very simple to set-up to tow.
38,782 PostsLatest Activity: Sep 02, 2026
