gatorcq
Jan 04, 2017Explorer
What transfer switch are you talking about?
Changing the shore power setting does not make it charge or not charge. The reason you change the shore power setting is due to all the other AC items that you may try to run off of 20 amps. This may help in NOT tripping the circuit breaker to the 20 amp outlet.
The red light, are you sure that is not the Surge Guard light?
