dougrainer
Aug 25, 2020Nomad
HighwayJunky wrote:
Plugged in the 110V plug which is in the basement area. The hose has a metal ring that I plug in to start the unit. Nothing happens! My Dirt Devil also has a floor kick plate where supposedly the unit powers up. Doesn't seem to work. Have tried other appliances using the sale plug. All works!!!!
I am starting to think the Dirt Devil itself is "BAD"....
Sorry, Dirt Devils are NEVER BAD. They just had a bad childhood:B You will see where the remote wires are connected to the base unit. Make sure they are connected. Since BOTH the wall outlet and the floor Vacpan have to have the Low voltage power wires and both do not work, the bad connection would be at the Main motor unit. If NOT this and the wires are connected, then the motor is probably bad. If you jump the 2 low voltage wires at the Pump, the unit should run. Doug
