I think we will see a lot of improvements from ASV. The Freightliner ( AKA Roadmaster) that they are using will be similar to the one used in the American coach line. It will be better engineered than the Roadmaster. FL build a chassis to SAE standards whereas the Roadmaster was really not engineered. You will see things like : real wire harnesses that are labeled, wires printed with their function. color coded air lines and more. But I don't know if anything rides as well as the Dynasty Roadmaster with 10 air bags. I am sure they will share components with other ASV vehicles. So when a computer board quits it will be available as it wont be something unique to Monaco. Fleetwood has awesome tech support and I assume Monaco will as well. How much support they will provide for those of us with older units is unknown. No Freightliner chassis ever had those mickey mouse trailing arms that Monaco built. I was under our Bounder DP that is on a FL chassis. I cannot believe the heavy duty components on the chassis. This will be a good thing for those who are looking at entry level units.
Moisheh
