jacksharp's avatar
jacksharp
2015 Thor Hurricane 34F TV's Not Working
OK... This is a good one. Under our TV we have a small cabinet (2015 Thor Hurricane) that we store our Videos in. There is a 110vac outlet there that our TV plugs into. Things were fine until we plugged in a small heater. Watched TV all evening, nice and warm... went to bed, and about 3am the little woman got up to go to the bathroom and noticed the heater was not working. Went back to bed, and in the morning told me about it. First thing I checked was the breakers... nope... all fine there. Next thing was the fuses... all fine there. GFI in bathroom... all fine there... The bedroom RV is also not working now, as well as the plugs in the area where our DVD player is located above the fridge. All else if fine. Did I miss something? Is there another ground fault located somewhere?
Thanks in advance for all your help...
Jack
  • Effy's avatar
    Effy
    Explorer II
    Are any plugs working at all? I assume you are on shore power not on gen. Did you check the breaker at the post? Is anyone else in your CG out of power? You can unplug from the post and test your system with your gen to rule out your coach vs CG power.
  • Flip off the breakers and if still nothing, then do the same with the GFCI. If not then check the wiring at the breakers. Could have not been tighten up secure. Volt check the wire connected to the breakers and the common white wire or bare copper.
  • There probably is a tripped breaker. Find which circuit controls affected outlets and turn it off, then back on.
