rcmiller32
Nov 22, 2014Explorer
You have the Class C chassis minus the cab. Might be able to check with ford to see if there is a tapped port on the transmission or lines for a sensor. Some of the prep packages did include a port or a gauge in the cab dash panel. Most likely not for this package. The RUV really pushes calling it a class A. Based on chassis. Yes in that the cab is the body of the unit.
Just wondering have you had it weighted yet with it full of your gear and fluids. I know past E350 chassis that I worked on and owned were always close to being maxed out on the front axle.
38,778 PostsLatest Activity: Jun 06, 2026
