j-d
Mar 06, 2017Explorer II
All I know is based on my nearly 20 years in Class C's, this forum, and the Born Free webpage.
Born Free is a great coach.
F550 is a great chassis, and it'll turn tighter than our E450, which would be a blessing.
I wonder why you don't want Diesel in such a high line coach. That said, the Ford V10 will provide plenty of power.
I found Born Free's website a little lacking in detail. The design seems to be what I'll call "Elegantly Spartan" such as non-carpeted floors and a fairly simple floor plan.
Maybe I didn't look carefully enough, but I couldn't tell if the electrical service was 30- or 50-Amp. Also couldn't tell if the 15000-BTU A/C was the only choice. This Imperial is probably about the same size interior as a "31" or "32" foot Class C, with the difference in overall length being the longer F-Series chassis.
To say, a 15000 A/C is marginal in a Class C this size. We get by with ours. It keeps us cool if we cordon the cockpit off. We often have to "load shed" on 30-Amp service. So... a couple points:
1. And this is above all: The FLOOR PLAN has to work for YOU. If it doesn't, keep looking, no matter how good the rest of the coach is.
2. Without being able to dig into the details, I'd like such an exquisite unit to be 50-Amp, with Two 13500 A/C units, feeding into one common discharge duct. That gives you plenty of cooling power, and you can have limited cooling with less amps of shore tie, or the failure of one A/C unit.
I wish there was better detail on the BF webpage.
