FormerBoater
Jul 03, 2018Explorer
dotcommer wrote:Dance Chick wrote:
That's a lot of people in a RV. Check the CCC (not sure what it's called nowadays??)...cargo carrying capacity....all the people's weight, all of your stuff, food, fuel, water, etc. That's going to be a big determining factor on whatever you buy. Also, enough storage for all of your things should be looked at.
How do you figure out how much Cargo carrying capacity weight you really have before going on a trip?
There will be a sticker inside each coach that gives you the pertinent weights for the unit.
CCC will be detailed there.
Know what the family weighs and subtract that from the CCC. This will tell you how much gear you can haul.
This may make the decision for you as the DP should have a higher CCC than the gas coach.
