jolooote
Aug 18, 2016Explorer
Look underneath to see if u have double mounting holes in both the front & rear Sway bars. These are the bars that are bolted to the axles and the coach body to reduce the coach sway left & right. most are installed by the factory using the first(easiest)hole. Rebolt it using the 2nd (tighter) hole. U'll be amazed at the improved handling.
38,781 PostsLatest Activity: Aug 12, 2026
