Lwiddis
Sep 25, 2020Nomad III
Generally, you need one solar watt per battery amp hour but living in Washington you may need 1.5 or 1.75 watts per amp hour. Have you consulted a solar wiring chart to determine proper wiring? I use 10 gauge from the panels to the combiner box, 8 from the box to the controller and 6 from the controller to the batteries but my 3 panels are in parallel. Wiring distance is important too...longer the distance the bigger the wire. Don't limit any future additional panels by using small wire. Consider doing your panels in series too. The controller you buy needs to specifically say it works with lithium batteries. You'll love not needing a generator! Seems your current fridge is a power hog.
