Goldencrazy
Dec 06, 2016Explorer
2016 Smart Car towing setup
I have been practicing going through the routine of getting the transmission set to tow. By placing the selector in mannual and holding the down shift lever until it reaches 6 and then disconnecting the battery using the pressure switch I had installed it is set to tow. The base plate from Blue OX is installed and lights wired. On Thursday I will connect to motorhome and take it for a nice test drive. The pegs are about 17 inches wider than my 2009 and three inches higher. The three inches should get me to nearly level which is nice as I use a 10 inch drop and am within three inches on the 2009. I expect the bid wider stance of the connection will produce a bit more stability although that has not been an issue with me. For those thinking about a Smart the new one has really improved in many ways. The ride is so much better and I do like the great HP which makes it very zippy.
