Expyinflight
Jul 06, 2017Explorer
From the Ford website:
Engine Specifications
E-350 / E-450
Engine type 6.8L Triton® 2V V10
Engine electronics EEC-V computer
Displacement 415 CID
Horsepower (SAE net@rpm) 305@4,250
Torque (lb.-ft. @rpm) 420@3,250
Compression ratio 9.06:1
Bore x stroke (in.) 3.55x4.16
Main bearings 6-bearing
Valvetrain SOHC, 2 valves per cylinder
Valve lifters Hydraulic roller finger
Fuel delivery Sequential multiport electronic fuel injection (SEFI)
Electronic throttle control (ETC) Std
Engine oil cooler Std
Exhaust Stainless steel
Transmission type TorqShift® 6-speed automatic with overdrive and tow/haul mode
Engine block material Cast iron
Cylinder head material Aluminum
F-53 / F-59
Engine type 6.8L Triton® 3 Valve V10
Horsepower (SAE net@rpm) 320 @ 4000
Torque (lb.-ft. @rpm) 460 @ 3000
Compression ratio 9.2:1
Fuel delivery Sequential electronic fuel injection (SEFI)
Recommended fuel Unleaded regular
Transmission type TorqShift® 6-speed automatic overdrive with Tow/Haul Mode
E-350 / E-450
F-53 / F-59
38,782 PostsLatest Activity: Aug 31, 2026
