pauliski
Oct 04, 2024Explorer
it sounds like your wiring is a little different that the 240fs but the reason the outlet for the fireplace goes dead
is because there is a "safety switch" that has to make contact when the slide is open all the way so then the fireplace can be used. the switch is on the track of the entertainment center slide on my unit. I adjusted it and now the fireplace works fine when you open slide and then open entertainment center.
38,777 PostsLatest Activity: May 20, 2026
