it sounds like your wiring is a little different that the 240fs but the reason the outlet for the fireplace goes dead
is because there is a "safety switch" that has to make contact when the slide is open all the way so then the fireplace can be used. the switch is on the track of the entertainment center slide on my unit. I adjusted it and now the fireplace works fine when you open slide and then open entertainment center.
While I am sure the op would have found this helpful, this post is 6 years old.
- MNtundraRetOct 05, 2024Navigator
"Freekie" will not see the reply. This was his last post/reply. I checked is ID.
- pauliskiOct 05, 2024Explorer
well I just joined the group yesterday and found the group doing a general google search for my problem. I knew there had to be some kind of switch to turn off that outlet that is just for the fireplace. I did not look to see how old the post was. Hopefully in the future someone somewhere will find my post helpful. Two dealer I spoke to had no clue why it was going dead and just wanted me to bring in for diagnosis. $$$$$$
- opnspacesOct 05, 2024Navigator III
I agree with Pauliski on this. True our current forum has a lot of quirks such as allowing replies on posts over a year old. But that doesn't negate the benefit of a poster giving good or helpful information that might help someone in the future.
- pianotunaOct 05, 2024Nomad III
The change from what was there to what is now has been a disaster. I used to spend time on the old format every day. Now it is rare for me to make a comment.
