craig7h
Mar 30, 2020Nomad II
I had a Thor ACE 2017 29.3. A little history first, we traded to the ACE from a rather large 5th wheel. We wanted to down size! After 2 years with the ACE we found out we downed sized to much so traded it.
The ACE is not quite the bottom of the Thor line but close (I knew that going in). As for the chassis with the V10 it was great I had no problem traveling the mountains of CO or the roads of MO. I pulled a KIA on a dolly the whole time.
All the appliances are the same in all units so that was not an issue. The black holding tank was a big issue. It was only 26gal plus the bath sink went into the black tank. Then there was an elbow just below the toilet that wanted to collect everything. That was my major complant. Make sure the ACE you are looking at has 2 AC's Mine had only one and it was a ***** to keep it cool.
There were other things that I did not like but that was just me so I will leave it alone. Would I buy another ACE maybe. I would check out the Thor forum https://www.thorforums.com
