DrewE
Aug 17, 2016Explorer III
I don't think any class C has anything like a good turning radius. They're all varying degrees of bad. Class A's are generally more maneuverable. I think tractor trailer trucks are probably also more maneuverable on the whole.
While many disagree, I like having a (gas) oven in my RV. (Admittedly, I'll like it a lot more after I repair it so it doesn't leak gas from the control valve.) I suspect the majority of people rarely if ever use the oven, though, so it's very common for it to be omitted in modern RVs. A grill can serve as an oven for many purposes.
I would not consider factory navigation a particular positive. Frequently they have a rather clunky user interface, and map updates are expensive. A smart phone or standalone GPS unit are at least as good and usually less expensive. The built in system does look a little cleaner on the dashboard, though.
38,782 PostsLatest Activity: Sep 10, 2026
