Dusty_R
Aug 22, 2016Explorer
You can put a pencil behind the switch to hold the pump on while pumping out the gray water tank.
On our 2015 Spirt 27Q gray tank drain there is a Tee after the slide valve. The pump goes into the side of the Tee, and the other end has a screw in plug. I replaced that plug with a reducer bushing, and put a 3/4" PVC street Ell in the bushing. Then a garden hose adaptor, then a garden hose valve and cap.
The gray water drains a little slow that way put that's OK. It don't need the pump.
Dusty
Dusty
