Dale_Traveling
Apr 12, 2019Explorer II
Placard pressures are not factory empty weights but are the pressure needed for the tires as supplied and the front and rear axle maximum capacities. The Ford placard will list the same pressure as what the Thor placard lists but how does Ford know which make or model house is built on the chassis or how much it might weight?
Stick with 82 psi which. It's a safe number that you can verify by cross referencing to Goodyear's tables against the placards for any make or model.
Next opportunity drive across a CAT Scale just to ensure the coach doesn't need to go on a diet. I to the scale run every spring and the first stop when we head out on summer vacation.
