Bren53's avatar
Bren53
2019 Coachman Leprechaun 319mb
Can someone tell me where to find the fresh water tank drain valve? We bought this new early summer then hubby had health problems. Never got the chance to use. I need to drain the water in fresh water tank out. I know the salesman showed us but since we have't used since i've forgotten. Thank you for any help with this.
  • Those valves you turned under the bed are near your water heater and might need to be repositioned in order for you to use your unit again. You need to allow water flow into the water heater and back out to the lines in order to have hot running water.
    Just google a pic of the diagram to show you the operating positions of those valves. They are the 'winterizing by-pass valves'.
    The valve handle (T) is in line with the water line to allow flow, that's the open position.
    If you did not have that panel inside the storage compartment, then look in the vicinity below the freshwater tank or below the 'water fill port' with the screw off cap to fill the water tank, that's a common area to find the drain lines.
    Many new units today drain the water tank as well as the cold low point drain, therefore it might take a few minutes to drain , depending how much water is in the tank.
    Drain lines in my unit are installed beyond the water pump and are visible when you look under the MH because they have to drain onto the ground.
    The cold line looks like an open end line because the on/off valve is inside the rv. The HOT line has a twist off cap at its end, that's visible from under the rv.
    (Look for two lines hanging down, one is open ended, one has the twist off cap)
    In order to see your drain valve, sometimes you have to remove a panel inside the rv under the fridge or stove. Look for a wood panel with a few screws , remove them and the panel to take a peek what's behind it.
    When you park it during storage, your shed will need to be heated if night time temps fall below 32F . You need to protect the water pump, toilet, H/C lines and those plastic valves on the faucets (kitchen, bathroom sink and shower, outside shower too) The water heater needs to be drained as well.
    You could use an air compressor to push air thru your entire system which would offer good protection to clear the water out of the lines and system. You can then add non toxic rv antifreeze thru the system for better protection because there would be only a little residual water remaining to NOT dilute the rv antifreeze, offering your system full protection. You would need an inexpensive (Walmart item) air valve stem that screws onto your city water hookup port.
    If you need more help to winterize, we can run you through the process.
    Hope your hubby feels better, that's the most important part.
  • If it is like my old coachman the valve knobs pull up to drain the tank. Then after it drains I close them by pressing back down and the drain whatever is left with the water pump and then blow out the lines with an air compressor before putting RV antifreeze in the lines using my winterize port.
    Good luck.
  • Thanks but ours didn't have the little panel. I found the two valves where our pull out kitchen is located. Our FW tank is under the bed and there is a valve there. I turned all 3 valves every which way I could but finally had to turn the water pump on to get it to drain the tank! Is that normal or did I miss something? Never had one that the pump had to be running to empty FW tank!
    We are actually going out in it this weekend. DH is feeling much better and wanted at least one weekend out with the grandkids! LOL
    We'll winterize it some time next week. It's parked in shed so is protected.
    Thanks again! I'm sure this won't be my last question on this MH!
  • Looks like Mike's gotcha covered re the question you asked, Bren. Gotta ask though: There's NO WAY that just draining the FW tank "winterizes" your MH..........right? On my WGO just doing that would net me a lot of broken pipes, valves and water heater here in Colorado.
    Wishing for a better health situation for your DH and that you get to use it next season. ed s
  • I have a Forester 3011 which is almost identical. My water drain is located in the outside compartment just past the rear axle. Inside that compartment, I have a small black plastic door. Open that door and you'll see a blue water line with a valve in it. Opening that valve will drain the water straight down.
