nickthehunter
Dec 02, 2023Nomad III
You can test the converter to see if it’s working by disconnecting the all the leads at the battery; then, while being connected to shore power, check the output on the 12V side of the converter. If no 12V output you should check the 120V input side of the converter.
No power in means there will be no power out. If you have power in but not out, you likely have a bad converter. If you have power in and out at the converter, you have problem(s) elsewhere.
