ron_dittmer
Jan 15, 2022Explorer III
jolooote wrote:In case someone with a 1992-2007 hood wonders why your hood is so heavy for you. They might not realize the change from fiberglass to steel in 2008 when Ford restyled the frontal area. My apologies.
WHY are you all talking about 2007 e-350's with plastic hoods???
Now back to solutions labeled under these names.
pneumatic hood strut
hood lift support shock strut
hood gas strut
hydraulic hood assist
Shopping around, you won't find any marketed for a Ford E-series vehicle. You will have to engineer through retrofitting struts for another application, vehicle or otherwise. Plan your mounting location with consideration to both open and closed positioning. You will also need to explore the appropriate strut mounts.
I realize you are hoping someone else has already successfully addressed this, but you may be paving a new road. I have been on RV forums since 2007 and I never read anyone else discussing this topic before.
I wish you well with a resolution.
38,782 PostsLatest Activity: Sep 02, 2026
