- bobndotExplorer III
bobndot wrote:
Look inside the storage compartment near the freshwater tank for a hinged black door. Access to water pump and valve to drain freshwater , which on my FR is also the cold water low point drain.
On my FR , the low point drain lines can be seen by looking rearward of the passenger side dual wheels, near the mudflap.
When you drain the H/C low point drains, the cold side will take longer to drain depending on how much freshwater you are carrying . Its a dual function drain valve.
In many rigs , the freshwater tank, gravity water fill port, water pump and low points are in the same general area. - bobndotExplorer IIILook inside the storage compartment near the freshwater tank for a hinged black door. Access to water pump and valve to drain freshwater , which on my FR is also the cold water low point drain.
When you drain the H/C low point drains, the cold side will take longer to drain depending on how much freshwater you are carrying . Its a dual function drain valve. - bukhrnNomadLook under the queen bed.
38,782 PostsLatest Activity: Sep 10, 2026
