dougrainer
Aug 31, 2021Nomad
Since it is a 2022, Have you checked with Ford to make sure YOUR unit is not part of the Rear end recall? You need to. IF you are part, it was determined that Ford did not fill the Rear Differential with enough OIL and there is a nation wide Back order of NEW Rear ends that Ford is having to replace. AS of Friday, Tiffin had about 8 new built units on their lot that cannot be driven to the dealers because they must have the rear ends replaced. You are not allowed to drive the Motorhome as the rear end could fail at any time. Doug
