Based on the questions, I’d question your ability or experience to do this, but…
To answer your questions, rather than ask the questions before even verifying what you’re asking, why not actually run the procedure and it will answer your questions.
PS, you don’t actually have to tow it down the road to verify what you’re asking. And as a side benefit, you’ll learn something rather than being told it and likely understanding less.
Also yes, trans in park is the right way for reasons mentioned above. There is no magic to disconnecting the battery. Pick one or the other posts to disconnect. Neg is best for reasons you can look up.
Don’t be surprised when you have to redo any pre set electronic things.
Any universal battery disconnect that fits the battery post will work although new vehicles have cables generally routed “perfect” with little play and semi vehicle specific connections, so may have to move some stuff around or modify the battery connection.
- Toolguy5Jun 14, 2025Explorer III
Grit Dog
What a real jerk you are. not just with this post but others you have replied to that I read after you replied to mine.
You don't know me and you don't know my abilities.
