enblethen
Jun 13, 2014Nomad
Kwikee is now owned by "Powergear.com"
Yes, parts are available. I would replace the pump completely as the pump head costs nearly as much as whole pump.
Step could be binding and needs cleaned good on pivot points and then sprayed with good quality lubricant. Chain lube from motorcycles work good. Another thing to check is the ground on the step assembly's connection to the frame of the MH.
38,766 PostsLatest Activity: Jan 10, 2026
