tev123's avatar
tev123
22x47 solar panels on intervec falcon roof
Anyone installed solar panels on the roof of their intervec falcon?
I am looking to install one 100w 47"x21.3" panel, with option to add one more later.
I am debating whether to install behind the AC unit, sideways, or in front of the AC unit.
If I install behind the AC unit:
pros:
- minimal wind drag when driving as it sits behind the AC unit
cons:
- takes up some space on the rear roof where I could otherwise go up and sit to watch a sunset or the likes... with one panel, I still have enough room to sit up there but if I later add a second panel it would take up the whole space.
If I install in front of the AC unit:
pros:
- no used up space in the rear section, so I can use rear for sitting and/or carrying some light loads
cons:
- may make wind noise or create drag; could be hit with debris.
other option is one up front and later on one behind.
Anyone has done this before that knows other pros/cons or preferences?
Thanks!
  • Esox---Who says they are not good performers? Haven't been able to find that anywhere.
  • Flexible panels are not good performers. Don't worry about drag from solar panels, it is minimal. Plan the location of your panels where they will get the least shade from other roof appurtenances.
  • You can get flexible 100 watt panels on ebay. I installed it on the roof of a conversion van. Used the strongest adhesive tape sold and sealed it around the edges. No drilling or wind drag. A little more expensive but worth it in my opinion.
  • I suggest making up a portable frame out of 3/4 inch pvc then you can put the panel anywhere and not worry about the roof.
