Desert_Captain
Feb 02, 2020Explorer III
jdc1 wrote:
Ford V10?
Get the GM. You would be astounded at the volume of Ford V10's at the mechanic's shop I used in Riverside Ca. Never saw a newer GM there.
That is most likely due to the fact that the Ford chassis' outnumber the Chevy's by at least 100 to 1 not due to any inherent reliability issues with Ford. The V -10 is hands down just about the most bullet proof motor Ford {or anyone else for that matter} ever built. Start counting Ford vs Chevy when it comes to Paramedic Ambulances and air port shuttles and other commercial applications then start counting Class C's... :R
Now if you are over 6' tall or the first number when you step on the scale is larger than one you may benefit from the couple of extra inches found in the Chevy but the difference is modest. The Ford power drivers seat is the best in the industry with almost infinite adjustability and easily overcomes with comfort the slight edge of the Chevy's extra inch or two.
Of bigger concern is any street side slide as these will restrict/eliminate the ability to fully slide back and or incline the drivers seat and this goes for both Ford and Chevy. The ride and handling are a toss up, both are one ton cutaway vans and neither will ride and or drive like your SUV.
When selecting either be sure and check the payload as when C's get larger the payload tends to all but disappear, less than 2,000# doesn't work very well and some large C's {anything over 30'} often have 1,000# available or less. :S
As always... Opinions and YMMV
:C
