bobndot
Dec 18, 2022Explorer III
Your camping style is like ours. We usually can’t depend on neighbors to help us. It goes beyond the size of the rv. Once you fit into a campsite you need everything to function properly in order to not have to leave.
Your first rv ? As you know, Rv’s are much more complex than a tent . Especially boon-docking remotely. Rv help is few and far between today. You need to learn the very basic mechanics and how to override things in order to make them function while you are in remote settings. Carrying a few extra parts may be the answer for you to keep yourself on a site rather than leaving to try to get help , which might take considerable time.
Spares: You need to have a ‘water pump’ , ‘ pex tool with some extra clamps’ , a universal ‘ Dinosaur Fan50 control board’ and an ‘LP regulator’. You need to have these in order to have flowing gas and water and appliances that function. The control board operates the fridge, WH and furnace. I have replaced all using quality made Dinosaur boards and never had another issue.
I would go 24’ and make it work. If you choose a slide model, make sure you can use the floorplan completely when the slide is ‘in’. Just in case the slide motor fails or the slide binds in its frame and you unable to hand-crank it back in. Smaller , lighter slides of 400 lbs can sometimes be pushed back in. Larger full wall slides 1000 lbs need a team of linemen.
The ‘pivoting’ into tight spaces might be the key to getting in. See which brand, GM / Ford E series / Ford Transit / MB , offers a better turning radius.
A shorter wheelbase rv seems like it would navigate over humps and rocks that might otherwise get hung-up on the undercarriage of a longer WB rv. The middle of a coach could become hung-up on the ground . That will also depend on your coaches ground clearance, which could be increased by using spacers if necessary. A spring shop could do that.
Notice the rear overhand distance of the rig you decide on. The distance from the rear axle to rear bumper. This is where rvs can get hung up while trying to back into an incline. The rear sometimes digs in to the dirt on an incline.
We use our 24’ non slide rv for a month at a time with no issues. If you can do a month then you can do a year. We have a corner queen bed and a full queen in the cabover which is all storage space now.
Closet space, fridge size and LP tank size should be considered. Learn how to downsize everything you need. It can be done .
Doing laundry more often, replenishing food and propane might have to be done more often than a larger rv. Just some things to consider beyond the extra 2 feet or whatever length you are considering.
Consider a spare tire and appropriate jacking. Many rvs do not have spare tires. If you need to add one, you could use a hitch mounted tire carrier off the rear hitch.
Carry 2x10 blocks for leveling under the tires. Absorption fridges need to be somewhat level to keep the gas flowing to operate. 12v compressor fridges will work fine off level.
38,780 PostsLatest Activity: Aug 05, 2026
