Gjac wrote:
what is the difference between the 350 and 450 chassis. Is it just suspension, or is transmission, rear end, and frame upgraded also.
Newer than 2016 there is little difference between 350 and 450. Once Ford stopped making the E series van as a standalone vehicle, much was consolidated. They essentially threw all the HD parts on all E series to eliminate options and simplify build sheets among upfitters. As of 2019, drivetrain is absolutely identical; engine, transmission, axle ratio, etc. Brakes are identical all around. Cooling system is identical. 450 rear axle is a different PN and slightly different measurements (to accommodate different springs) but ratio is the same (4.56 for all.) Both have hydroboost. Both have the 6 speed.
The biggest difference in my research: Frame thickness and dimensions, springs, and sway bar specs are dependent on WB and GVWR for both the 350 and 450. As the 450 has higher GVWR for longer floor plans it is generally thicker frame/springs/sway bar in 2016+.
