Gjac
Jun 21, 2021Explorer III
Gjac wrote:Interesting point, how much wider is a 450 chassis compared to a 350? Is this still true with the newer chassis?DrewE wrote:I don't care what they call it either,. I just thought that a lower profile B + MH, 9 ft 10 ins vs 11 ft 3 ins for a C would have a lower CG and feel less tippy going around mtn roads with corners. If the ride is the same the "solid advantage" of the C is more exterior and interior storage and more FW capacity. The aero front end does not seem to help the ride as some have posted.Gjac wrote:
I guess the next logical question is if a B+ and C of the same length ride the same as some have posted and the two still need the same suspension mods what is the real advantage of a B+ over a C?
I don't think there's any solid advantage or disadvantage, since the "B+" designation is just a marketing distinction for a smallish class C that (generally) has no cabover bunk and maybe an above-average trim level. It's hard to say one is inherently better than the other when they're basically just different names for the same thing.
That being said, if you find a unit that meets your needs and has a layout you like, does it really matter if the maker decides to call it a class B+, or a class C, or a class F4, or...well, anything? To my mind, that seems to make about as much of a difference as whether the model is named after a summer resort area rather than a species of tree (or, should it be a toy hauler, a military aircraft).
