faucet1
Oct 09, 2018Explorer
Don't know about the 6.7, but the 5.9 Cummins had a problem with cracking of the Manifold due to heat. In the MH application, the 5.9 units couldn't get proper cooling and caused the Manifold to get hot, warp, crack. That particular setup had the engine torque at 660 ft-lbs. Don't know if the newer 6.7 may have some of the same problems. Hopefully, the manifolds are much improved. I suppose the higher weight Coaches made that engine have to work harder. FWIW.
38,782 PostsLatest Activity: Sep 10, 2026
