darsben1
Jun 27, 2016Explorer
dougrainer wrote:darsben1 wrote:
TO THE OP:
I CONTACTED WINNEBAGO THIS AM.
Yes it can be a Winnebago problem. Depending on model there was a big recall of Winnies for defective rubber hoses.
The oil in the hose was leaching out of the lines and flowing to the regulator and clogging the regulator. Cure was new hoses.
See my PM for more information and contact details at Winnebago
Where did you get that it is oil contamination from the hoses. The recall I am aware of, is, the crimp fitting on the hi pressure side may leak, NOT that the oil leached from the LP hose. Doug
"Winnebago Industries, Inc. (Winnebago) is recalling certain model year 2013-2016 Winnebago Era, Travato, View, Trend, Via, Journey, and Tour motorhomes and Itasca Navion, Viva, Reyo, Meridian, and Elipse motorhomes manufactured June 26, 2012, to August 26, 2015. In the affected vehicles, the high pressure liquid propane (LP) hose may harden and result in an LP leak at the crimp fitting".
AS I SAID at the request of the OP I contacted Winnebago Industries this A.M. The person I spoke to; whose name I obtained told me that "they had a problem with oil in the hose was leaching out of the lines and flowing to the regulator and clogging the regulator. Cure was new hoses." He further stated Winnebago had a recall and sent letters to all affected owners. My guess is they missed the O.P. maybe because of his location.
I have sent the info to the OP so he and Winnebago can hook up
