darsben1
Jun 27, 2016Explorer
dougrainer wrote:
This recall is for the hose to be replaced and the LP regulator and the Oven/range regulator. In addition they install a drain drip pipe for the LP oil to get trapped without affecting the LP gas going to the system. It is NOT oil leaching from the hoses. there is no oil to be leached from the hoses. They replace the hoses and the other parts to get rid of the contamination. The contamination is from the LP supply. That is why I asked. Hoses do not leach oil. Doug
Guess that is between the op and Winnebago now. I called, I asked and I got an answer.
My part is done.
Maybe you can take over helping the OP as I know nothing about oil contamination in GAZ. You seem to be well versed so have at it.
