MrWizard
May 05, 2015Moderator
So you can make it work, with a DIY adapter... using the ground for a neutral
IF YOUR installed ground wire is large enough
That does not make it a safe practice, or something to describe on this board
What you are describing, is an emergency/disaster make do situation, because lives depend on having power
Because you have to and it might work
That is not something to post here
38,782 PostsLatest Activity: Sep 01, 2026
