wolfe10
May 21, 2015Explorer
Cliff,
There is a lot more involved in adding another hot/going from 30 to 50 amp service.
The 120 VAC main breaker box needs to be changed out to accommodate the L1 and L2.
And, yes you will HAVE TO HAVE a ground back to the CG ground (which is grounded at the CG main breaker box).
Another alternative is to keep your coach wired for 30 amp and split out the feed to the second A/C. Use a HD extension cord exclusively to power the second A/C and plug it into the CG 15/20 outlet.
38,782 PostsLatest Activity: Sep 01, 2026
